Re: Can a third hydraulic outlet be added to 806?
Posted by David Saville on May 03, 2002 at 22:09:57 from (142.165.111.78):
In Reply to: Can a third hydraulic outlet be added to 806? posted by Steve on May 03, 2002 at 03:31:00:
Yes you can do it by stacking a third valve in between the first two. BUT that is the easy part. You have to make a new left hand seat support that gives clearence for the third valve and you have to invent your own control lever and linkage. Treat the inside and the new valve as the originals when hooking up the lines to the connector bodys and then hook the new hoses to the outside valve.
Post A Followup
: Re: Re: Can a third hydraulic outlet be added to 806?
