Re: Crankshaft and flywheel
Posted by David Saville on May 03, 2002 at 22:28:07 from (142.165.111.78):
In Reply to: Crankshaft and flywheel posted by Bruce on May 02, 2002 at 10:32:35:
Did you find the locater pin between the crank and the flywheel? It is threaded so you can put a bolt in it and pull it out. I think when I did my W30 I pulled the crank and flywheel as one piece but they have to come apart to change the bearing. I think I also put the flywheel back on before I put the crank back in the block. Sorry about the "I think" but it is a few years since I did mine.
Post A Followup
: Re: Re: Crankshaft and flywheel
