Re: Finally putting it back together....
Posted by Theman on May 04, 2002 at 05:40:10 from (12.19.86.5):
In Reply to: Finally putting it back together.... posted by Steven@nd on May 03, 2002 at 19:28:42:
Looks good Steven. I don't know what your plan is down the road when it comes time to put the frame rails on, but the upper rear bolt on the oil filter housing may have to come out to get the top frame rail bolt in on that side...unless it is already in the rail when you set it in place. I've never had much success juggling parts with bolts in them. Also, verify that all your oil passages are clear. I found the center cam bearing off a bit from the machine shop and had to run a long drill down the block to open it up to my satisfaction. I wish you the best.
Post A Followup
: Re: Re: Finally putting it back together....
