Re: M
Posted by howard on May 04, 2002 at 19:33:40 from (65.172.143.89):
In Reply to: M posted by Stink on May 04, 2002 at 19:14:17:
you might try welding yours. carfully chamfer the broken ends and place on the theaded half. tie with baler wire to hold in place and use nickel rod. you will need to have the whole assembly off the tractor to do this. good luck.
Post A Followup
: Re: Re: M
