Re: Re: Re: Update: Help on loosening exhaust manifold bolts!
Posted by Ol Chief on May 04, 2002 at 21:01:10 from (24.162.28.111):
In Reply to: Re: Re: Update: Help on loosening exhaust manifold bolts! posted by RockyMountain8N on May 03, 2002 at 10:20:40:
I do not know if you are working on bolts or nuts .If its bolts,suggest you find a good substantial brass or copper piece of bar stock.Use it as a punch against the bolt head to jar the threads.This often will help loosen galled fasteners.Also helps oil to penetrate.I am a marine engineer and you can bet we have plenty of frozen bolts to free. Also a real aid to this sort of problem is bees wax used with heat. If you heat the bolts rub a stick of bees wax on while temperature is falling.The wax will find its way into very tight places.
Post A Followup
: Re: Re: Re: Re: Update: Help on loosening exhaust manifold bolts!
