Re: Generator on SMTA needs help?
Posted by Bob M on May 05, 2002 at 17:59:59 from (66.66.72.246):
In Reply to: Generator on SMTA needs help? posted by dave westlund on May 05, 2002 at 16:20:14:
Dave - First make sure the regulator base is solidly grounded to the frame. Ror a quick check, run the motor at about 1/2 throttle and have a helper watche the ammeter. Then:
1 - Connect a jumper wire between the regulator BAT and GEN terminals. If the ammeter now indicates charge, replace the regulator.
2 - If still no charge, now connect the jumper between the regulator F terminal and a good ground. If it charges, again replace the regulator.
If 1 and 2 give no results, problem's with the generator. Best bet is to take it to a reliable starter/alternator shop.
(Note!! The above of course all presumes the wiring is in good shape and properly connected.)
Good luck!!
Post A Followup
: Re: Re: Generator on SMTA needs help?
