Farmall Tractors Discussion Board
Re: Re: Re: Re: Re: Re: Re: Re: Farmall A Cooling
Posted by Phil Auten on August 10, 1999 at 05:34:43 from (206.175.72.226):
In Reply to: Re: Re: Re: Re: Re: Re: Re: Farmall A Cooling posted by Ray on August 09, 1999 at 18:07:26:
Ray,
The STP is just a patch, your engine is in need of new bearings (probably the cam bearings are shot).
You can continue to use it, but the damage may cost you a lot more to fix later.
Good luck, whatever you do,
Phil
Post a Followup
: Re: Re: Re: Re: Re: Re: Re: Re: Re: Farmall A Cooling
