Re: Re: sticking valves - Super H
Posted by jal-SD on May 06, 2002 at 08:35:19 from (64.68.166.199):
In Reply to: Re: sticking valves - Super H posted by The Red on May 06, 2002 at 08:07:48:
Sounds to me like the gas might be too "dry"-remember these things were designed to be run on leaded gas-lead used to lube the valves. It might be a good idea to use some marvel mystery oil in the gas when you start it & get it warmed up. Are you using Stable in the gas? Maybe you will want to take the air intake off @ carb & squirt some marvel directly into it before you shut it off just before you store it. (My $0.02 worth. jal-SD)
Post A Followup
: Re: Re: Re: sticking valves - Super H
