Re: pto gremlin in 61 cub
Posted by Kajun on May 06, 2002 at 15:15:32 from (216.78.133.88):
In Reply to: pto gremlin in 61 cub posted by gshaw on May 06, 2002 at 06:57:58:
gshaw:
Cub pto is simple device. External shifter moves pto collar foward onto engine drive shaft. Once fully foward the pto is engaged. What you describe is probably caused by a worn shifter which is allowing collar to partially engage the drive shaft. Go to archives and search under "kajun" and "Cub". You will find procedure for changing shifter and collar if necessary.
Regards
Kajun
Post A Followup
: Re: Re: pto gremlin in 61 cub
