Re: Help! My Farmall M will not start.
Posted by PaulH on May 06, 2002 at 15:23:34 from (151.142.252.11):
In Reply to: Help! My Farmall M will not start. posted by Nathan Oberdier on May 06, 2002 at 15:16:32:
Sounds like either a bad battery cable or a bad battery. I have seen a battery look good on a voltmeter, but suddenly develop an internal high resistance, so it would drop to almost zero under load. If the cable clamp is loose or corroded, it would do the same thing. That's assuming you're measuring voltage from the switch terminals to ground or battery negative. If you're measuring voltage across the switch, the voltage should be 12 V when not actuated, and near zero when pushed.
Post A Followup
: Re: Re: Help! My Farmall M will not start.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
