Re: Help with clutch
Posted by ScottyNY on May 06, 2002 at 20:24:19 from (128.59.42.163):
In Reply to: Help with clutch posted by Dave KY on May 06, 2002 at 16:59:02:
Dave, there should be two adjustments you can make to the pressure assembly. Both can be made pretty simply on a good flat surface. One is to make sure that the pressure plate is even in relation to the cover. If it's the standard rockford design, you'll finds six springs with adjusting bolts torugh the center. With the pressure plate resting flat on your bench, adjust these springs so that the lower edge of the cover is 27/32" above the bench surface all the way around. Then go around the bolts that adjust the fingers. Loosen the jam nuts on them, and turn the bolts until the surface of the fingers that will contact the throwout bearing are 2-5/32" above the bench surface. Double check that you haven't disturbed the 27/32" that you did before, and tighten the jam nuts on the finger adjustments. This should get things back in the range where your pedal linkage adjustment will take care of your free play. These are the dimensions Larry was referring to. Hope this helps. Scotty
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
