Re: Farmall H rear main seal
Posted by Doc on May 07, 2002 at 01:01:46 from (24.118.181.39):
In Reply to: Farmall H rear main seal posted by Ben Cleaveland on May 06, 2002 at 06:05:31:
Are you sure it is the rear main and not the seal on the belly pump or the front of the transmission? If you aren't, remove the clutch cover off the bottom, block the wheels and crawl under there with the tractor running. you may spot one or all of the other seals leaking. That could be your leak, or you may want to change them while things are at least partially apart. Doc
Post A Followup
: Re: Re: Farmall H rear main seal
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
