Re: Super C Governor
Posted by gene b on May 07, 2002 at 18:45:02 from (67.251.189.136):
In Reply to: Super C Governor posted by Custer on May 07, 2002 at 18:31:08:
yes it is on the top might even have the safety wire on it back it out till you have the rpm you want the lever and shaft that the hand throttle goes on gets worn and the slop keeps it from reaching desired rpms the shaft can be shimmed on the inside this will remove unwanted play good luck gene b
Post A Followup
: Re: Re: Super C Governor
