Re: Re: Torque question
Posted by dick on May 08, 2002 at 10:02:00 from (65.59.16.34):
In Reply to: Re: Torque question posted by howard on May 08, 2002 at 05:22:13:
Something easy to look at which will give you a good clue about whether you're likely to run into a problem with a T/A is the clutch adjustments. The main clutch pedal should have about 1-1/4 inch of free play before reaching the friction point. The T/A clutch should also have free play, on the 300U the spec calls for about 3/16 inch of free space in the T/A clutch adjustment clevis, but this probably varies in other models. Another thing to look at is the amount of adjustment left in the adjustment clevis - which can give you an idea of how worn the clutch is.
I've looked a number of IH tractors with T/As and maybe 50% have had one or both clutch adjustments wrong. Took one of these for a test drive, and had the transmission lock up (didn't buy that one).
Post A Followup
: Re: Re: Re: Torque question
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
