Liftall question for M
Posted by Tom W on May 08, 2002 at 12:25:34 from (166.94.9.204):
I have a 33A loader on a 49 M that is conected to the lift all. I works fine when you first start to use it and will pick up a lot of weight. After a while it looses a lot of lift. If you turn the tractor off and let it set for about an hour it will work fine for a while. I have changed to Oil and have 6 qt of 30W non detergent in it. Do I need to overhaul the pump or is it something simpler than that?
Post A Followup
: Re: Liftall question for M
