Re: Re: Re: 1956 Farmall - Color of Grill
Posted by Dave_Id on May 09, 2002 at 06:25:43 from (67.250.102.121):
In Reply to: Re: Re: 1956 Farmall - Color of Grill posted by Jim on May 09, 2002 at 06:16:07:
If you are absolutely possitive it's a 1956, (casting dates), then the ser. # for a 350 will be between 501 and 1029, if it's a 1956 300, then the ser. #'s between 23224-29578 or 30508. (info from Guy Fayes IH Data Book)
Post A Followup
: Re: Re: Re: Re: 1956 Farmall - Color of Grill
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
