Re: how to stop a sediment bowl valve from leaking?
Posted by Pawnee on May 09, 2002 at 10:37:07 from (207.51.255.129):
In Reply to: how to stop a sediment bowl valve from leaking? posted by James (MO) on May 08, 2002 at 08:54:02:
I pulled out the old packing and put in a small rubber o ring. This cured the valve from leaking. Mine now leaks from around the top of the bowl because the gasket material i used there is not suitable. TSC sells this gasket by itself but i have not bought it yet. If you try to repair your current bowl,I wanted you to be aware it could leak from either spot. Lots of options. Good Luck
Post A Followup
: Re: Re: how to stop a sediment bowl valve from leaking?
