Re: Re: Re: Got my M converted
Posted by Bob M on May 09, 2002 at 14:21:34 from (66.66.72.246):
In Reply to: Re: Re: Got my M converted posted by Dank on May 08, 2002 at 19:05:38:
Pulsating at low RPMs could be caused by the alternator drive belt slipping. Check for loose, worn or oil-soaked belt. But as the others have noted, so long as it charges I wouldn't worry about it!
Post A Followup
: Re: Re: Re: Re: Got my M converted
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
