Re: farmall h float
Posted by Zonie on May 09, 2002 at 17:14:42 from (152.163.204.61):
In Reply to: farmall h float posted by Bob on May 09, 2002 at 16:51:35:
If the float is set too high, Gas will run out of the drain hole in the inlet to the carburator. the engine may smoke black and run really rich or flood out.
I have to find my service manual to check the float adjustment. as memory serves me i think it is as you said , the float is level with the carb body, but my memory doesn't serve me too well lately!
Post A Followup
: Re: Re: farmall h float
