Re: C carb
Posted by BIG JOHN on May 09, 2002 at 18:39:40 from (152.163.197.64):
In Reply to: C carb posted by Eric WI on May 09, 2002 at 10:50:41:
The following is from the IH Service Manuel.
"Set the float level to specification using a standard 6-inch depth gauge. CAUTION: Do not bend, twist or apply pressure to the float bodies. NOTE: with the throttle body in an inverted position and viewed from the free end of the float, the float bodies should be centered and at right angles to the machined surface of the throttle body. The float setting is measzured from the machined surface to the highest point on the float bodies. The depth gauge should read 1-5/32 inches.
To increase or decrease the distance between the float body and the machined surface, use long-nosed pliers to bend the float hinge close to the float bodies".
GOOD LUCK
Post A Followup
: Re: Re: C carb
