Re: unfamiliar territory :diesels
Posted by doug vose on May 09, 2002 at 18:55:14 from (12.89.1.175):
In Reply to: unfamiliar territory :diesels posted by jfee on May 09, 2002 at 17:20:39:
You probaly have some air in your fuel lines. Check to be sure there is fuel, then make sure the fuel is turned on. then if all is good there, unhook one of the injector lines and crank the engine over, if there is no fuel, then you have air in your system. what we did with olivers to bleed the lines, we just towed the tractor around in 5th gear and let it craank untill it fired up, but you would prolly have better luck if you bled the system like the manual says to do.
Post A Followup
: Re: Re: unfamiliar territory :diesels
