Re: unfamiliar territory :diesels
Posted by Red Baron on May 10, 2002 at 06:06:45 from (165.139.135.249):
In Reply to: unfamiliar territory :diesels posted by jfee on May 09, 2002 at 17:20:39:
You probably twisted off the pump drive shaft. Take off the small inspection cover on the side of the injection pump and see if the head is turning when you crank on the engine. If ti is not the pump will have to be removed and sent ot a pump repair shop.
Post A Followup
: Re: Re: unfamiliar territory :diesels
