Re: Need Generator help please
Posted by Bob M on May 10, 2002 at 07:58:56 from (165.170.128.66):
In Reply to: Need Generator help please posted by jtwaldo on May 10, 2002 at 04:42:23:
Definitely sounds like the battery is being overcharged. Proper operation with a good, fully charged battery is for the ammeter deflect hard to the right immediately after startup. It should then gradually taper down until it shows a small charge level (deflection slightly to the right of 0) after running at speed for a few minutes.
Possible causes for overcharge: New regulator is bad (not likely if you got it from C&G, but still possible). Wrong regulator part number was provided (again not likely). Wrong connection(s) made at the regulator. Short to ground in the wiring that connects the generator and regulator F terminals. Internal short to ground on the field winding in the generator.
A couple quick tests: With the motor running and the ammeter showing charge, disconnect the wire from the regulator F terminal. If the ammeter now shows discharge, problem is in the regulator. If it's still charging, disconnect the wire from the generator F terminal. If the ammeter now shows discharge there's a ground in the wire harness. If it's STILL charging with the wire off the generator F terminal, problem's a short inside the generator. It needs a visit to your local starter/alternator shop!
Post A Followup
: Re: Re: Need Generator help please
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
