Re: converting back to 6 volts
Posted by jal-SD on May 10, 2002 at 10:04:03 from (64.68.166.199):
In Reply to: converting back to 6 volts posted by Hal Davis on May 10, 2002 at 09:32:59:
Pull the battery cable off. Connect +post of 6V battery to bolt on starter where its bolted to the bell housing w/GOOD jumper cable. (Your H originally was 6V +ground.) Connect other jumper cable to -post of 6V. Touch the copper bolt's nut w/other end of cable connected to the -post. If starter turns the engine over, its still a 6V. It will turn over a LOT slower on 6V than 12V. Remember the watchwords for 6V - clean, bright & tight, even w/this process. (Be careful to keep sparks away from the battery-you'll have some sparks!) (My $0.02 worth. jal-SD)
Post A Followup
: Re: Re: converting back to 6 volts
