Re: Super M belts
Posted by Bob M on May 10, 2002 at 11:36:02 from (165.170.128.66):
In Reply to: Super M belts posted by Greg on May 09, 2002 at 20:17:25:
Belt change on an SM is not terribly difficult: 1 - Loosen (unscrew) both the generator and water pump adjustable sheaves. Do this by unscrewing the locknut and 1/4" set screw in the rear halves of the water pump and generator sheaves, then unscrewing the each sheave half as far as it will go. This will loosen the belts. Plan on finding the adjustable sheaves being stuck on their threads - a liberal application of WD-40 and some quality time with a hammer and punch are often required. (Note: This is usually the most difficult step - often it's easier to simply cut the old belts off THEN attack loosening the adjustable sheaves.) 2 - Once you get the sheaves opened up all the way, walk the fan belt off the crank sheave, then off over the fan blade and out of the fan shroud. Then repeat the process with the generator belt (despite how small it looks, the gen belt WILL fit over the fan blade!) 3 - Now reverse the process to first install the new gen belt, then the fan belt. 4 - Once the belts are in place, set the belt tension by tightening the adjustable water pump and generator sheaves. Lock the sheave adjustments with the set screws and locknuts. Note: These belts don't need to be very tight to work properly. About 1-1/2" of mid-span slack in the fan belt and 1" slack in the generator belt is good.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
