Re: Re: Re: farmall h popping
Posted by Michael Soldan on May 10, 2002 at 16:12:18 from (216.46.130.15):
In Reply to: Re: Re: farmall h popping posted by Dan Kelley - Quick way to check manifold leaks on May 10, 2002 at 07:03:46:
Dan, some propane( from an unlit torch ) directed around the manifold will cause the engine to smooth right out if there is a leak because the propane is sucked in and burns as a fuel, you can use acetylene for good results as well.You can definitely tell by the sound of the engine. Mike in exeter ontario
Post A Followup
: Re: Re: Re: Re: farmall h popping
