The 42 H runs!!
Posted by Steven@nd on May 11, 2002 at 07:43:11 from (12.23.184.96):
Only worked on it about 3 hours yesterday - most of it after 8pm too. Got up at 5 this morning and buttoned everything up - installed sediment bowl and fuel line, checked for leaks from the water I put in last night, etc.
Pushed it out of the garage, set throttle to about 1/4, hit the switch and it started like it was shut off yesterday!! A little smoke from the oil on top of the pistons, but that cleared up instantly. Pulled the drag around the yard for a while too, pulls good. Already have 1 hour on it!
Feels good to hear it run!
Steven
Here is a couple close up pics of those rocker arms that had to be raised up to allow clearance. They are a little bit off center, but I'm not going to lose any sleep over it.
third party image
Here is the rocker arm all the way up, valve closed.
third party image
Rocker arm down, valve open.
third party image
third party image
third party image
third party image
third party image
third party image
third party image
third party image
Post A Followup
: Re: The 42 H runs!!
