Re: Re: IH 300 u Stuck motor - need help!!
Posted by William Ransom on May 11, 2002 at 14:13:22 from (65.167.44.55):
In Reply to: Re: IH 300 u Stuck motor - need help!! posted by AL on May 11, 2002 at 04:15:56:
third party image
This M had a locked up connecting rod bearing. I could only reach one of the bolts, but after I removed that one I could turn the flywheel with a pry bar and then remove the other one.
Post A Followup
: Re: Re: Re: IH 300 u Stuck motor - need help!!
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
