Re: No Spark from mag
Posted by Craig MO on May 11, 2002 at 18:46:28 from (216.139.97.2):
In Reply to: No Spark from mag posted by Mass. Mike on May 11, 2002 at 13:19:37:
Just had a C in the shop that threw me a fit. It would start and run for 30 secs. to a minute then die. Found wire form points to condensor had a break in the wire outside covering was good but when it got hot wire would seperate inside. Made new wire and runs like a top again. Something to check. Or like BIG JOHN said somthing is touching grounding it out.
Post A Followup
: Re: Re: No Spark from mag
