Re: Thrust bearing?:THE RED
Posted by The Failing Memory Red on May 12, 2002 at 06:38:07 from (12.84.238.55):
In Reply to: Thrust bearing?:THE RED posted by Will@ont.ca on May 12, 2002 at 03:37:35:
Will it has been a couple of years. I do have on my computer desk the governor from Old Rusty H. You have to take the speed lever assembly and the shaft it bolts onto out. The main bearing is pressed into the governor case and I don't recall any clips, etc. holding it in place. I don't think I removed the gear from the shaft. I think I somehow rigged a puller and pulled the whole assembly out. Once it is out, the thruster bearing assembly slides off the back end of the shaft. The job was fairly easy and didn't take all that long.
I need help on this Farmallers!!
Post A Followup
: Re: Re: Thrust bearing?:THE RED
