Re: Sealed beam lamps to fit Farmall H?
Posted by Farmer Bob on May 12, 2002 at 07:44:52 from (66.152.73.216):
In Reply to: Sealed beam lamps to fit Farmall H? posted by Bob in SE Nebraska on May 12, 2002 at 06:31:25:
Your Case/IH dealer should be able to hook you up as the later Cubs ('64) had 6V sealed beams in the tear drop like buckets. They are different than the older Guide light tear drops but look similar./FB
Post A Followup
: Re: Re: Sealed beam lamps to fit Farmall H?
