Re: Re: How can I remove the transmission cover to replace the bull pinion cage on the brake axle on a FARMALL C ?
Posted by JD Humm on May 12, 2002 at 16:02:00 from (67.25.233.132):
In Reply to: Re: How can I remove the transmission cover to replace the bull pinion cage on the brake axle on a FARMALL C ? posted by Slappy on May 12, 2002 at 07:28:29:
Also are a couple of bolts under the instrument box, if you haven't found them yet. The instrument box and the control tower assembly must be removed.
Post A Followup
: Re: Re: Re: How can I remove the transmission cover to replace the bull pinion cage on the brake axle on a FARMALL C ?
