Re: Farmall B pto lever
Posted by Roger on May 12, 2002 at 18:19:08 from (209.100.170.181):
In Reply to: Farmall B pto lever posted by TL on May 12, 2002 at 16:26:31:
If just the lever broke off that can be changed from the outside. If the shaft going into the housing broke, you will have to take off the PTO housing. That is fairly easy as you just have to drain the transmission fluid and remove the bolts that hold it on. The shaft is easily accessible from that point. Roger
Post A Followup
: Re: Re: Farmall B pto lever
