Thanks :Steven, Big John and Justin
Posted by Rollie on May 13, 2002 at 14:16:12 from (67.201.227.94):
I took a second look at the spacers I had installed under the rocker arm post. I have 3/16" spacers now and can not go any thicker because of bolt length and clearance between the valve cover and the tube that is over the rocker assembly.
I guess the easiest thing to do is to take the head off and change the valves. The head number is 6186 DF the block number is 6695 DE and the engine number is FBH 181433 X3. Would one of you guys be able to give me a part number for the correct valves. Thanks A Bunch .
Post A Followup
: Re: Thanks :Steven, Big John and Justin
