Re: Farmall C belts
Posted by Farmer Bob on May 13, 2002 at 14:52:47 from (66.152.73.112):
In Reply to: Farmall C belts posted by Steve Mason on May 13, 2002 at 08:42:20:
Steve, As RedDave said below...there is a nut on the front side of the adjusting bracket and another nut behind the bracket. If you stand on the generator side of the C, using a 13/16ths open end wrench on the front nut-raise up on the wrench to loosen it-you don't have to unscrew it all the way. There may be some junk in the slot below the back nut so clean the slot out so the fan shaft will drop down to its lowest point. Now work the fan belt off the pulleys. When putting the new belts on make sure you put the generator belt on first and then the fan belt. I use a long heavy duty screw driver under the back nut to raise up the fan shaft. When you get it to where there is about 3/4" flex in the belt in between the pulleys, tighten the front nut by pushing the wrench down. You may have to loosen the two mounting bolts on the bottom of the generator to allow is to swing in toward the motor for removing the gen. belt. Good luck.//FB
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
