Re: Re: Re: Farmall M not charging, AFTER rewiring. WHAT THE HECK?
Posted by The Red on May 13, 2002 at 14:57:51 from (12.84.238.108):
In Reply to: Re: Re: Farmall M not charging, AFTER rewiring. WHAT THE HECK? posted by Ken Christopherson on May 13, 2002 at 13:59:08:
Make sure the points are closing on the voltage regulator when the engine is running. If they are not, you will have to make an adjustment.
Post A Followup
: Re: Re: Re: Re: Farmall M not charging, AFTER rewiring. WHAT THE HECK?
