Re: f-20 narrow tread
Posted by Farmall Gray on May 13, 2002 at 15:37:48 from (205.188.199.174):
In Reply to: f-20 narrow tread posted by jim on May 12, 2002 at 15:10:09:
On a narrow tread the belt pulley is very close to the final drive housing. You have about 1/2"
to slip the belt in between. On the wide tread
version you have a good 6".
Post A Followup
: Re: Re: f-20 narrow tread
