Re: 1950 farmall C positive or negative ground?
Posted by gene b on May 13, 2002 at 19:12:07 from (63.25.166.37):
In Reply to: 1950 farmall C positive or negative ground? posted by Les Frie on May 13, 2002 at 18:54:11:
ALL 6V FARMALLS WERE POS GND apparently you dont read this column as these questions are very common you mite luck out if you polorize the gen just jump from the A term on the gen to the BATT term on the reg might work that is a momentarly touch just enough to get a spark AFTER you change it to POS gnd good luck
Post A Followup
: Re: Re: 1950 farmall C positive or negative ground?
