Re: Taking off Farmall A Crank Pulley
Posted by Red Raider on May 14, 2002 at 14:13:42 from (4.24.111.22):
In Reply to: Taking off Farmall A Crank Pulley posted by Pete on May 14, 2002 at 09:51:17:
You could pull the crank from the block without removing the pulley, of course the cam gear cover will be attached. Then get the machine shop to pull it for you to separate everything, cause they'll have to grind the crank anyway. A lot of aggrivation and risk to the pulley saved.
Post A Followup
: Re: Re: Taking off Farmall A Crank Pulley
