Re: Taking off Farmall A Crank Pulley
Posted by EZ on May 14, 2002 at 19:30:38 from (216.211.7.172):
In Reply to: Taking off Farmall A Crank Pulley posted by Pete on May 14, 2002 at 09:51:17:
You will probably be good to change the front crank seal as well. On my A the seal was finished, the replacement however was just under size to fit snugly into the timing cover. Use a bearing sealant to hold the new one in tight. Mine has no leaks now. We used a bearing splitter to remove the pulley, but be careful as the guys say you could break the outside. Be patient, Good Luck
Post A Followup
: Re: Re: Taking off Farmall A Crank Pulley
