Re: stripped threads on Cub
Posted by Andy Martin on May 15, 2002 at 10:29:55 from (12.74.161.118):
In Reply to: stripped threads on Cub posted by baman on May 15, 2002 at 06:38:37:
These holes usually go bad from not keeping the bolts tight over a long period of time. If they are just worn and not really stripped, new bolts will often fix the problem. A belly mower is not as bad a load as other implements so new bolts may fix the problem. Often the old bolts and old threads don't mate well and the threads look really bad but new bolts will take a nice bite. The tapered-shank bolts are a little hard to find. But you need them to fit the implements right. These holes would be a pretty large size for heli-coil but that should work unless the casting is cracked. Also, the castings are reversible. You can take the left off and put it on the right. So if you want to go to a lot of work, reverse the castings as the three holes in the front are very likely to be like new. If the castings are cracked a good machine shop can drill them out and weld in a new threaded steel bushing.
Home
| Forums
Today's Featured Article -
Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
