Re: Farmall A reves
Posted by Rob in Wis on May 15, 2002 at 19:34:07 from (205.188.197.167):
In Reply to: Farmall A reves posted by tiny on May 15, 2002 at 13:13:36:
I had something similar on my Super C a couple of weeks ago. The engine was in hi-rev and I couldn't get it back down. It turned out to be the linkage that the rod from the governor fits into on the throttle shaft at the carb. Somehow that link was busted and just spun on the shaft. I replaced that and I'm in business again. Good luck.
Post A Followup
: Re: Re: Farmall A reves
