Re: Re: Farmall M motor stuck
Posted by Dan Kelley on May 15, 2002 at 20:31:49 from (216.229.40.215):
In Reply to: Re: Farmall M motor stuck posted by Craig MO on May 15, 2002 at 19:58:20:
Also check to see if the trans is really in neutral. Try turning the engine over with the clutch in. If it turns, you've got a tranny stuck in two gears (or worse).
Try a wrench on the hand crank pin. The rings on my M took a set a while back, and a little pressure with the wrench popped it loose.
Post A Followup
: Re: Re: Re: Farmall M motor stuck
