Re: Farmall M motor stuck
Posted by Loren on May 16, 2002 at 12:33:32 from (209.150.202.19):
In Reply to: Farmall M motor stuck posted by Denny on May 15, 2002 at 18:50:18:
I've had good luck un-sticking pistons by using Iron Etch (made by Martin Seynour) which I purchase at NAPA. It's used for auto body work for preping metal. It's a bluish color, and I think the main ingredient is phosphoric acid. I broke loose pistons on a 10-20, A, and an M, and it's worked every time. I pour the solution into the cylinder about 1/2" deep on top of the piston, and let it sit overnight. The next day, put a bock of wood in the piston and start trying to drive it down. If you have help, another person can put a bar on the flywheel. Definitely take off the pan, so you can see the direction the crank should be turning, and you'll want to pull out the piston and clean up the cylinder anyway. It's been a while since I did this, but I think I removed the rod bearing caps and swung the rods over to clear the crank pins, putting a rag or cardboard between the rods and the crank pins to prevent damage. With the M rods, the caps should be at 45 degrees to allow you to swing them out of the way. By doing this, you can work on each piston individually, in case several are stuck. After the rods are disconnected from the crank, try taking a wooden dowel and driving the pistons up from the crank case. The ones that are not stuck should come out. Also, with the crank disconnected, you can rotate it out of the way of the piston & rod you're woking on. After you get the stuck pistons moving down, you may want to then oil the cylinder and drive it upward (can't remember if the piston will clear the crank if you keep driving it down.) You'll probably need to use a ridge reamer on the cylinders so the rings will clear the wear edge near the top of the cylinder. On the 10-20, the pistons had to be driven out the bottom because the bearing end of the rod is wider than the cylinder. The Iron Etch will leave the cylinder with a rougher finish where it sat overnight, so you'll want to hone out the cylinder. E-mail me if I can be of further assistance.
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
