Re: need help making towbar to pull MD home
Posted by Bob M on May 16, 2002 at 14:18:19 from (66.66.72.246):
In Reply to: need help making towbar to pull MD home posted by jmyt_47 on May 16, 2002 at 11:25:41:
I made up a drawbar like you describe to tow my SH and SM to a couple of local shows. Works great.
Seems to me the threaded holes in the lower bolster are 3/4" but I'm not positive. Also recommend stopping every few miles and checking the attachment bolts for tightness.
Heed the others' speed warnings - 20 mph max!! Make sure your tow vehicle is heavy enough, has a good hitch and has GOOD brakes. Remember you've got 5,550+ lbs pushing when you make a stop - it's effect on braking distance even at 20 mph is startling!! I also rig up an auxiliary flasher powered from the tow vehicle. I hang it on the tractor PTO shield below the SMV in order to be clearly seen by vehicles approaching from behind.
Post A Followup
: Re: Re: need help making towbar to pull MD home
