Re: Farmall 140 Question
Posted by Hugh MacKay on May 16, 2002 at 14:33:31 from (64.228.12.25):
In Reply to: Farmall 140 Question posted by Marty Hundley on May 16, 2002 at 12:53:56:
Marty: You've been awfully quiet lately, must be busy tending to those potatoes you planted almost two months ago. I supose its possible you are eating new potatoes by now. Up here they would have icicles on them.
On the Farmall 140 other than sheet metal, I believe the only changes made were solonoid was added and later models were key start. They also changed them to 12 volt. I suspect this all happened around 67-68, although not sure. There may be other changes I am not aware of. Not a lot of the later ones around with belt pulley, not sure if it was droped or so few people using pulley it became an option. I took the pulley off my 130 as I never used it and it was a nuisance hooking up to pto. Hugh
Post A Followup
: Re: Re: Farmall 140 Question
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
