Re: Re: 4386 pro's con's
Posted by Hugh MacKay on May 16, 2002 at 15:37:27 from (64.228.12.185):
In Reply to: Re: 4386 pro's con's posted by robert on May 15, 2002 at 16:34:39:
The first year these were introduced I looked at specs and declared it would not work, reason, too much weight and rubber on ground for engine. If you look at new articulated tractors today, any make. They are all pushing 300hp and 600 cubic inches.
IH had the same 50 years ago in the 113 and 123 cubic inch engines. They would give you a lot longer service in an A, Super A, 100, etc than they did in C, Super C, 200, etc.
Post A Followup
: Re: Re: Re: 4386 pro's con's
