Re: Knocking in Farmall H second gear
Posted by Casey on May 16, 2002 at 17:41:24 from (205.188.196.26):
In Reply to: Knocking in Farmall H second gear posted by Bryce on May 16, 2002 at 16:21:15:
Your NUTZ for spliting the tractor to do a tranny job on an H! i bought an H about 7 months ago too and i boguht it as is, and it had a terrible nock ni all gears! which indicated the consant mesh and main drive gears were chiped. to make a long story short just drop the hydrolic pump and and clutch and unbolt your shafts and pull them out!
i just finishe mine fri afternon still havnt goten arond to start it and test it out!
-casey :any advice just holla
Post A Followup
: Re: Re: Knocking in Farmall H second gear
