Re: F-20 Flywheel removal
Posted by F20 in MI on May 17, 2002 at 05:03:55 from (12.47.76.196):
In Reply to: F-20 Flywheel removal posted by Jim on May 16, 2002 at 10:40:19:
I used a very heavy duty three legged puller to remove mine. A 1/2 inch impact wrench and it was off in couple minutes. The cocner with pushing it off is that you will damage the bearings. Ball bearing do not like to be loaded in that direction. The key comes off with the flywheel. A regular gear puller will not handle the loads. Installation is much easier. Heat the flywheel on you gass grill to 200 degrees. Install a bolt in the pin. You will need three people to iunstall the flywheel. Two to slide the flyweel on and on to install the pin simulataneously. It will slide right on.
Post A Followup
: Re: Re: F-20 Flywheel removal
