Re: what's the socket size for spark plug on 560?
Posted by J.D. on May 17, 2002 at 11:32:56 from (205.162.22.120):
In Reply to: what's the socket size for spark plug on 560? posted by dvtw on May 17, 2002 at 11:18:14:
You will need a 7/8" deep well thin wall socket. There isn't much room between the plug and the cylinder head so it has to be a thin wall socket, or a normal one ground down to fit. Both the Champion and AC version of these plugs use a metal gasket for sealing. Make sure you don't have any dirt or grit in the threads or on the sealing surface on the head. If the threads are dirty or damaged and the plugs go in hard, you may want to use a thread chaser on them. Sorry I can't help you on the seals.
Good Luck,
J.D.
Post A Followup
: Re: Re: what's the socket size for spark plug on 560?
